I don't want to be totally useless ... but you really should try to get it on a dyno, or at least borrow a (edit)mates(/edit) lambda meter (exhaust gas oxygen levels) and do it thoroughly.
The heads are the same between the two motors (unless you've changed the ports or cams etc inbetween) so the flow characteristics of the engine are going to be very similar too - *except* higher up in the rev range where you may be able to flow more air (although maybe not as efficiently).
I've always gone about things by getting the main jets right *first* and then do the secondaries/idle etc (granted i've never touched a mikuni/solex, but it's just how i go about things on other carbies)
Sorry i can't be of more help
