Yes, you can use the W50 on the 18R-G and the 18R-C engines. It's just a bolt in.
FYI, the original gearbox that was used in the 70s for the 18R-G GT/GTV spec Celicas was the P51. It uses the same gearbox casing as the W50. The P51 is a tougher gearbox with slightly different ratios (not much diff at all) than the W50, but the W50 is plenty strong enough to sit behind an 18R-G.
The W50 was used on the 18R-C engined vehicles of that time.
Not sure about the 5R. Being an R-engine a part of me says yes... but without seeing the engine or knowing anything about it I cannot commit that it would be a quick and simple bolt in.
Hope this helps.
seeyuzz
river
