Rancid,
The mods to the flange people are most likely refering to is the Diff Flange where the tailshaft bolts up to. You will need to have the tailshaft modified with the right flange to suit your choice of diff. This is not an issue tho as when you fit a bigger diff you generally need to change the length of the tailshaft anyway.
If you look at this poor quality pic the diff flange is visable and you can see 2 of the bolts that hold the tailshaft to it. As you can see its allot bigger than a stock RA28 one. (That pic is a Hilux diff in an RA28)
						 Re: RA28 Help
 Re: RA28 Help
