hey man, i just might be interseted in some RC engineering injectors if you can cut a cheapish/cheaper deal....Originally Posted by 1200det
send me a pm or i'll send you one later tonight![]()
Interesting comment there on the Venom injectors.
Thanks for the heads up.
Michael B
'84 MA61 with 7M-GTE
Now 5sp, 5 stud,17x8" Ray's, big assed brakes and decent IC
Better turbo in the wings as well as MAFT !!!!
more indecisiveness from me!
http://cgi.ebay.com/ebaymotors/550CC...14214630QQrdZ1
are these any good, does anyone know??????
also, i read somwhere (can't remember now) that you can use high impedance injectors and low impedance injectors in an engine that used low impedance injectors stock, but not low-impedance in an originally high impedance system... can anyone confirm this?
because i am also tempted to get a set of series V RX7 injectors, part number ending 2020, like glen's car, coz i've found a set and sick of not having injectors lol...![]()
thanks for all the help fellow toyota fans![]()
Dont know about the injectors, but that guy's feedback for the last month or so is pretty shite.
These are an option, tried and tested, denso low impedance rx7 jobbies http://cgi.ebay.com/ebaymotors/HKS-5...QQcmdZViewItem Clean em up and ur away. rx7/nissan/old toyota clips are like 10 bucks each max (i know, just bought some from SAS, I have the same 1370 denso injectors)
Personal opinion only from me is go for the RC Engineering Injectors i can get you some second hand hardly used for $300us
i've just put a bid on some on ebay! shit!Originally Posted by 1200det
If i lose them, ill get them off you alrighty?
thanks mate, i'll let you know, hopefully i lose the auction!
cheers,
ryley
Originally Posted by Ryley
if the p00 motor requires high impedance, you can use either high impedance injectors.. or low impedance with a resistor pack like most toyota engines used to use
if it originally used lowZ, WITHOUT A RESISTOR PACK, then it does peak n hold... the hold may not be high enough to keep high impedance injectors open..
however if the motor originally has either high impedance.. or LOWZ WITH a resistor pack, then the ECU does plain on/off signals, and so you can use either, as long as you use a resistor pack with the lowZ..
or you get a megasquirtwhich does both,,,
thanks guys, most appreciated. informative thread!
turns out i just won a set of RC engineering 550s for the 7m off ebay. $400 us. includes clips and polished fuel rail. less than 5000 miles on them.
the 7m's journey to the dark side is almost complete![]()
thanks again guys![]()
Congratulations on the RC Engineering injectors , With the clips and wires thats a pretty good price you will be happy with them
You going the LEX and 550 route ?
yep, got the lexus AFM on the way, as well as a S-AFC2. Have a boost controller sitting in my room too.
I'm aiming for 180rwkw plus with that combo... who knows how i'll go.
Do you have a 7mgte?
thanks for your help too![]()
I got three Z20 series Soarers all 7MGTE powered
The 180rwkw will be no worries at all im running 160rwkw in my Automatic Soarer with a drop in filter and cat-back exhaust
My 5speed soarer is using the RC 550cc and Lex combo etc although its awaiting a SP61Turbo to arrive from the states.
ah yeah, just found the mz20 thread. i want one of those too!!Originally Posted by 1200det
My 7M also has a rebuilt head, proper headgasket etc, full 3" exhaust and dump pipe, high flow cat. Probably put the boost controller up to 12psi.
I'd love 200rwkw, but I think that may be a bit ambitious...![]()
