Results 16 to 19 of 19
Thread: Engine angle ...hmm
    Nov 2007
    Default Re: Engine angle ...hmm
    I think OC is referring not to shaft angle, but rather that the gearbox and diff yokes need to be on the same plane eg. both plumb in order that the changes in velocity vs rotational postition (inherent in universal joints when run at any angle other than 0 deg) be anulled.
    dats da one
    (both of the previous 2 posts)
    meh, if it vibrates, you'll know what to change
    5-10mm is fine. My 2JZ in the MX83 looks like its sloping back, but its really not.
    Apr 2007
    I agree with the others, but if you are really concerned can you put a spacer under the gearbox mount to raise it up slightly ..
    I pressume you are using a spirit level or similar to get your 5 - 10 mm incline angle ?
    As you said the angle of the gaurds etc can make it look a lot worse ..
  1. Toyota R Engine History
    Last Post: 02-12-2011, 08:41 PM
  2. 4age 20v Silvertop - Check engine light?
    By Macross in forum Tech and Conversions
    Last Post: 29-09-2010, 08:45 AM
  3. TG engine info!
    By MitchE in forum Tech and Conversions
    Last Post: 30-07-2010, 06:27 PM
  4. MA70 --> JZA70 Conversion
