Results 1 to 4 of 4
Thread: 4age head gasket thickness
    Junior Member Backyard Mechanic cri_ag's Avatar
    Default 4age head gasket thickness
    after not much luck searching, i was wondering if any one new how thick the standard 4agze headgasket was? im after a copper one and have been given the following options,
    http://www.scegaskets.com/pdf/pg%2047-51.pdf (page 50)
    also why would there be a different listing for 4age - 4agze? all the thickness are the same but the gze has a larger bore opening size? maybe for rebored engines?
    cheers,
    craig
    Default Re: 4age head gasket thickness
    I have just recently gone throught this also and I was trying to find a Cometic MLS gasket to replace a standard thickness gasket.
    The replacement Cometic gasket over standard was 1mm thick.
    Im sure the listing would be the same for a Smallport GE to a ZE. When ordering mine this was the case.
    Good luck,
    Jeremy
    ToyotaCarClub.net Domestic Engineer Starfire's Avatar
    You could always get a nice thin one and pick up a bit of extra compression
    Just remember that it will effect your cam and ignition timing so reset those after you refit the head. If you dont have adjustable cam wheels you should get some - they look cool and they make cam timing easy
    thats what i thought but there is definatley two listings, with different bore sizes.
  1. will 4age head fit on a 4afe bottem end?
    By born_rolla in forum Tech and Conversions
    Last Post: 02-05-2006, 11:21 PM
