The ONLY pins you need to measure are E2 and IDL.
With the throttle 100% closed, E2 and IDL should be continuous.
With the throttle just cracked enough to raise the revs a few hundred, the E2 and IDL contacts should go open circuit.
If once you know you have this set, and the car is still playing up, the TPS is probably stuffed.
Just make sure it stays in the little grooves Mitch, assuming it's the same as my GTE.
