Shane, you wont have any problem running like 20 PSI through the intercooler.
If the SC is going to like running that much boost or if the ECU is going to deal with it and the change in air mass is an entirely different matter.
thats why i was keen to see what boost you actually end up with with a certain pulley ratio.
From what i have read upto 13 PSI should be ok but i think you might be pushing your luck / engine life much past that.
The other thing to consider is the higher you go the more losses you get on the water pump and general efficiency of the SC.
I would start conservative and see what boost you get stock first. Then go from there
Its not difficult to put a larger pulley on later.
Just my 2 cents
Edit i think yor server at work doesnt like me, my to last emails have bounced![]()
I will do some cutting and pasting in a moment
) only problem i'm having now is to convince myself its safe to do? keepin in mind this is my daily aswell as my weekender and sees abit of track work which option would u go?
) and the standard computer and injectors are supplying enough for a full load 12.5:1 AFR (Innovate LM1)
