fixed for j00Originally Posted by Draven
i thought toyota only had cruise on auto cars and none on manual?
well, in syd traffic cruise is useless
only,on motorways/freeways would it be helpful
Only aussie released cars.
JDM ones always had the option with manuals.
Rubbish. Don't assume that because *you* find it useless everyone else does. I don't find it useless - in fact I find it useFUL. I also live in Sydney and I probably drive more than youOriginally Posted by Draven
This is one (I assume) marketing decision that makes absolutely no sense to me. On an IS200, in particular, the ONLY extra hardware is the switch in the steering wheel, and the slightly different spiral cable - absolutely all of the other hardware is already there. If all Subarus have it, why is Toyota insisting on including a detriment? Go Toyota Australia - great work.Originally Posted by CrUZida
It's fairly lucky, though, that the looms are the same, so the ability exists to retrofit factory cruise components with minimal effort. The biggest problem would probably be installing the switch without destroying the asthetics of the steering wheel or column surround.
Have you found any parts yet, JCMO?
Mos.
Not as yet, now I've got a list of the parts I need, I need to find out where they're located in the car. Helps if I ask for a certain bit and am able to just tell them where in the car it is.
(head pulled in)Originally Posted by rob
fyi toyota does employ cruise control in vehicles equipped with manual transmission
i pulled three hundred rocks from the land to build my house
i walked quiet through the forest like a tiny quiet forest mouse
the oceans will rise
please stand by the shore
C-4 Cruise control actuator - between left strut tower and firewall.Originally Posted by JustCallMeOrlando
C13/C14 Combination switch - looks like the cruise control switch is part of the combo switch and not the steering wheel though it's not entirely clear
C15 Cruise control clutch switch - clutch pedal box
C16 Cruise control ecu - upper section of centre console
S11 Stop light switch - brake pedal box
Mos.
true, original post editedOriginally Posted by Mos
Thanks Mos! You are a god amongst men!
