Results 16 to 30 of 34
Thread: REAR Height Adjustable Spring Seats Suit AE86***HELP***
    Default Re: REAR Height Adjustable Spring Seats Suit AE86***HELP***
    The bolt on rear coil overs offered by T3 are not a good thing neither the body or the diff are deisgned to take the load
    Not disputing this but with the amount of money decent shocks and springs cost along with the adj perches and the time to fit it its not exactly a cheap path to travel. Besides, with the aud performing so well youll get a set of the coilovers landed for less than the cost of the shocks here.
    Your also doing body mods to mount an 85mm coilover spring, plus modding the diff for the perch anyways.
    Just because its cheap doesnt make it a good design. You may as well spend the coilover + reinforcement money on just getting it right the first time around.
    Sure, ive run a sub 1:27 out there before. Im more pointing out the fact that going into northern you will have the rear end step out on you because of the suspension setup you already have, let alone with coilovers.
    But obviously you dont want to listen to people who have experience with the chassis.
    if "race car" = "drift car" then the binding suspension will be good for helping the back step out
    Quote Originally Posted by newbien
    not interested in T3 junk...
    and Ignition Proned Race Ae86....A048's will have more than enough grip to run a sub 1:27
    hahahah, just read this...
    how funny poor guy
    ahh i read your shopping list thread, if you are lucky they won't bind
    Quote Originally Posted by LeeRoy
    Exactly my point form takai, building a "race" car isnt a cheap operatin. what i idealy would be doing is building my own coilovers (using 2612 series konis) modyfiing both the body and the diff and mounting them in the most effective location (depending on the rules of the catagory the car is designed to race in). but the cost would be outrageous, by the time you and up, parts, my time and materials. but thats what i would be doing if it was a car i was asked to build.
    Its all about budget. my initial suggestion of just getting a few pairs of springs made would be best IMHO, get some std low kings intialy and than test the car before changing the rear spring you may find they are perfectly suitable.
    without a watts link there is no such thing as quick height adjustment. as each time you adjust your rear or front hight you need to move change the length of your panhardbar.
    Also OC is also correct, thats the reason i suggested putting a eurethane bush or 2 in your rear end just to give it abit of give. specially with a panhard bar. i cant see it being smooth.
    vic
    As the title suggests....
    I'm after pics and or info regarding any and all height adjustable spring seats around to suit the rear of the AE86...
    Greddy Type S for AE86:
    ...stolen from another forum.
    they look just like TEIN ones.... i guess Greddy looks better on the shopping list than TEIN
    vic
    These are from a mob called GP Sports?
    http://www.gpsports.co.jp/
    ..dont know much about them? Seems to be a few of these similar kits getting about now - there are a couple of mobs in the states making them too. I'm thinking about getting the Greddy set-up for my track car, seems pretty reasonable for the price?
    All the same crap, different smell.
    To be honest you would be better off making up a set of your own fronts with the rates and inserts you want, and then using good inserts for the rear with standard springs.
    I've got the Greddy setup with adjustable spring Seat in my 86. These spring seats are not on car adjustable. There is simply not enough room to adjust them while they're on the car. I thought I let you know
    vic
    Sorry to hijack newbien's thread. But this is what I'm trying to work out too - is it better to go with a custom converted strut or is the Greddy set-up just as good without having to stuff around with building your own.
    I will be starting with the same spring rates that the Greddy set uses anyway and I'm sure you could get other ratesto play around with. I dont really care too much for the adjustable rear spring perch, although some adjustment is better than none I suppose. The price is probably similar between the two options (Greddy and custom conversion) except with the Greddy its all ready to go in one package - no stuffing around. I think it basically comes down to the quality of the damper? Well thats my thinking anyway? Please correct me!
    Backyard Corolla Kid Grease Monkey
    before we go any further...its not to suit an ae86...similar but different
    i wouldnt be going down to an 85mm id...and the cost in re-enforcing the std mounts to accept the t3 coilovers would outweigh getting parts made...
    how funny poor guy
    i was waiting for you to come in.....
    im considering changing my four link over to a cusco variation...being bushed on the chasis side, spherical on the diff end........
    ill get back to this thread tomorow...
    One, you title this thread "suit AE86"
    Second, the car you have listed in the rides thread is a T18, which has EXACTLY the same suspension setup as the AE86.
    Believe it or not, the suspension will behave pretty much exactly the same...
    just need one bush, or maybe two depending on what exactly you are trying to achieve with your roll steer and roll/steer on power/decel. It is easy to model to see what happens.
    but as you are seemingly very skilled and have thought about it, you will know where they go
    ps, no idea why you were waiting.....
    yes, they do share the same suspension components/geometry, however the t18 chasis is known for being a weaker chasis base, due to the pillar-less design....
    so i figure i will have a touch more movement in the rear end...
    i just knew that you would be in here at some point...hahaha....
    i was only going to be changing the upper arms over to the cusco formula's....still trying to sort out equal length boxes at the moment, this will decide on the arms that end up in the car....
    By The Witzl in forum FAQ
  2. GZ20 Adjustable Rear Camber Arms (need some)
    By gztwenty in forum Tech and Conversions
    Last Post: 19-02-2008, 12:05 AM
  3. Suspension for dummies
    Last Post: 13-09-2007, 08:38 PM
