Page 1 of 8 123 ... LastLast
Results 1 to 15 of 110
Thread: Rover 3500 V8 - Information for conversion
    Not known unless ur blown Backyard Mechanic
    May 2007
    Default Rover 3500 V8 - Information for conversion
    In the early landrovers and rovers in general they brought out a 3.5L all alloy V8
    Does anyone know much about these motors or what the actual name of the motor is so I can look it up??
    Cheers from lewi
    (shifted from general car talk, not sure what section to be in)
    perth
    Default Re: Rover 3500 V8 - Information for conversion
    i can find out for you but it will be on monday, a few units up we have one of the main rover garages in perth.
    what info did you need, im sure if you search google for 3.5 or 3.9 rover v8 you will get bulk info or try searching rover 3500 sd1, sd2.
    they are a shit motor tho, all of them. Ive seen heaps of people try do them up with bad results.
    Junior Member Backyard Mechanic Stock_22's Avatar
    Jun 2006
    Rover V8:
    Type: V8- cylinder, aluminium construction with 5 bearing crankshaft and self adjusting hydraulic tappets.
    Bore: 88.9mm
    Stroke: 71.12mm
    Displacement: 3528cc (215 cu in)
    Comp Ratio: 8.13.1
    Max Power: 134bhp @ 5000rpm (100kw)
    Max torque: 187.0 lbf @2500 rpm...
    "He who speaks doesn't know, he who knows doesn't speak..."
    May 2007
    Stock_22 - looked into this option already?
    Fixeruperer - May be a shit motor in a heavy car, lightweight celica could be a different story though, especially with just normal NA upgrades: Headwork, Cams (pushrods and lifters inthis case) & injection.
    Jun 2006
    Quote Originally Posted by Radar
    No, used to own an 80's vogue rangie, was a beast (guzzled fuel but was awesome offroad)...
    However, I wouldn't put one in a celica mainly because the fuel economy is terrible and they are not the easiest of engines to mantain... lots of money in spare parts. In a Rangie, they are great torquey engines. But not ideal for a celica.
    perth
    i dont meen there a shit motor just becuase they are slow they are actuly a shit motor hehe they break all the time blow headgaskets chew cam lobes outs, crack heads and when they overheat they die.
    and i have only heard one good sounding one.
    Jun 2006
    Quote Originally Posted by fixeruperer
    Can't personally speak for the 3.5L petrol, having never owned a Landie with one. But I can vouch for the 4.2L V8 petrol... Thats the pick of the lot (nowdays they run Jag engines, which are even better).
    perth
    it would have been bmw not jag, bmw bought rover a few years ago but it has now been sold again.
    don't you blokes watch top gear? They had a segment in episode 8 season 4 about it. http://www.finalgear.com/shows/topgear/4/8/
    personally I don't see what's wrong bout the old 1uz
    Hello.
    Zub Zub Domestic Engineer Gavatron's Avatar
    Adelaide, SA
    No kidding. Why go for some British lump when you can have one of the best V8's; and made by Toyota?
    Insert whitty comment her Automotive Encyclopaedia blacktop's Avatar
    Aug 2006
    I went 4WDing with a Range rover nut! he reckons the the v8's they come with are the worst motors in existence! he imported a twin charged 4.9 (don't quote me on capacity) rover engine from the UK to use in his rangie i think he calls it "Blown Crazy" or something.
    Aug 2006
    NEVER USE ANYTHING BRITISH<>EUROPEAN FOR A CONVERSION! (ITS ALL RUBISH!)
    and a landrover V8? that almost deserves NEG REP, *(used to work for landrover and volvo.... ever thought why the rangerovers switched to BMW v8's?) coz landy couldnt build a motor to save itsefl!
    i would own a KIA CARNIVAL before i own a landrover....... (aaarrrgggghh end rant )
    stick with the jap stuff (hate to say it,and the local stuff) and your laughing!
    Montrose
    I'd fit an LS1 before using one of those contraptions... Sure, you can get plenty of 'tuning parts' from the UK for them, but overall frought with difficulty and dramas. Why not a 4V/5V early Toyota V8? Still a light pushrod V8.. And at least it looks slightly tough!
    Rover V8 = head gaskets and oil leaks till your wallet dies. So much money for a gutless fuel guzzling POS.
    LS1 all the way. If you must, a Windsor.
    Those 4/5V Toyota V8s are just too esoteric - bit are just too hard to find for them. And they're almost as wide as a 1UZ, without the wholesome goodness of a 1UZ.
  1. Tuning Information
    By MADcunz in forum Tech and Conversions
    Last Post: 28-05-2007, 09:38 PM
  2. Information needed on balljoints
    Last Post: 16-08-2006, 06:33 PM
  3. Toyota Technical Information (TIS)!
    Last Post: 07-07-2006, 11:38 AM
