Results 1 to 4 of 4
Thread: 4A-C Thermostat & Temp Sensor
    Write English! Grease Monkey GasedT18's Avatar
    Default 4A-C Thermostat & Temp Sensor
    Hi all,
    RWD 4A-C
    can anyone tell me what temperature the thermostat on a 4A-C opens at?
    Can anyone tell me what voltage the temperature sensor should read at 'normal' engine temperature and what position on the dash temp gauge the needle points to at that voltage?
    D
    T-18 SE series 2 1982 3T-C dual fuel, now under resto
    3T-GTE rebuild with fancy gas bits under consideration
    AE71 CSX 1984 auto
    Parts Wanted ASAP - See Parts Wanted
    Feb 2008
    Default Re: 4A-C Thermostat & Temp Sensor
    96 Degrees F, thats what is written on mine, that converts to 35.6 Celcius
    My Temp sits cruising stable on the second notch, not the red one the one before it.
    Feb 2008
    I think I cannot read the writing correctly
    should open around 87 Degress C
    Thanks mikey,
    that's a start - will test my thermocouple meter and thermostat tomorrow.
    My gauge barely gets to the first line. Methinks this engine is running too cold and possibly why the choke is sluggish to release.
    The hot air inlet thingy on the air filter inlet doesn't seem to have the customary flex tube to exhaust manifold area.
    Can anyone tell me the specs of the Temp sensor?
    AE71 CSX 1984 auto
  1. Testing Oxygen Sensor
    By Z2TT in forum Tech and Conversions
    Last Post: 12-07-2008, 06:31 PM
  2. 4EFTE Coolant Temp Sensor Vs Microtech LT8
    By s-twig in forum Tech and Conversions
    Last Post: 11-06-2008, 07:46 PM
  3. Toyota diganostic error code, where can i find them?
    By MarkIIRx12 in forum Tech and Conversions
    Last Post: 19-03-2008, 01:42 PM
  4. 1JZGTE With Microtech LTX-12...what air temp sensor?
    Last Post: 16-02-2006, 11:38 AM
