Results 1 to 9 of 9
Thread: can I replace my L40 4speed g'box in my 4wd hilux with a w5X gbox?
    1uz 4wd Hilux Grease Monkey Dust's Avatar
    Default can I replace my L40 4speed g'box in my 4wd hilux with a w5X gbox?
    I currently have a 1981 18r powered 4wd hilux, it has an L40 4 speed gear box.
    I am going to put a 22r in place of the 18r and while I am at it I Would like to also put in a 5 speed g'box. I have searched around toymods and googled a heap and found that an L5X would be a replacement but am not too sure where to find one. However I do have a W52 from a 2wd hilux and would prefer to use this, rather then buying a new gearbox.
    So my question is, will the w5x fit in the place of the L40? as far as fitiing to the transfer case goes, I am fairly confident of it fitting to the 22r
    Help appreciated, thanks.
    vic
    Default Re: can I replace my L40 4speed g'box in my 4wd hilux with a w5X gbox?
    One word = NO
    Go and get yourself a L50 , shit box also
    or a G52 from 84 onwards . yes you have to move the crossmember back a bit but you wont regret it after your done .
    10 times nicer to drive .
    Dave
    dave: does the transfer case from an older 4WD bolt onto the back of an early 2WD G52? Or do you need a transfer from a 4WD that was attached to a G52?
    reason i ask is that out in the paddock is an '81 4WD hilux oil burner in need a new engine/box (and preferably petrol powered).
    you can have my 4 speed when I am done with it if you want it, no charge, not even beer
    but yeah, I would like to know what he asked as well
    Thanks,.
    lol ... having travelled on highway at a max of 85k in the use - 'cause that's all it would do - i'd say the 4sp is only good for a boat anchor
    vic
    Unfortunatly the 2WD output shaft is longer than the 4WD one so it wont go , all you can use is the gears inside the box.
    Dave
    So a 4wd G52 will fit in place of my L40?
    Or will I need the G52 transfer case as well?
    vic
    Yes the transfer as well as shortining the rear tailshft
    Dave
    dave, one last question: the G52 is used by the diesels only? or both petrol/oil burners?
  1. 3RZFE engine to replace 22R engine in 95 model hilux ute
    By Luxmod in forum Engine & Driveline Conversions
    Last Post: 25-06-2008, 09:00 AM
  2. 3RZFE engine to replace 22R engine in 95 model hilux ute
    Last Post: 10-04-2008, 09:21 PM
  3. Hilux - BA Rotors - Nissan GT Calipers
    By infotechplus in forum Engine & Driveline Conversions
    Last Post: 20-02-2008, 07:27 PM
  4. Hilux Tow Bars and Wheels
    By Son of Toyoda in forum Tech and Conversions
    Last Post: 26-06-2007, 06:09 AM
