you said there is no coolant in atm? none at all? can you smell fuel in the radiator?
none as i just put the engine in & then put the radiator that came with the car not engine in (just sitting in with bottom hose not tight), ill smell for petrol soon
one other thng to check, is that you have voltage at the coil on the + side, when the key is in IGN position, sometimes the power can get switched off when key goes back to IGN position from START.
i know i had voltage as i had the ballast resistor off & the coil heated u while the key was in on & i get spark
if you get sparks, gap is set right, and you reset timing to 10.. and the leads are on the correct cylinders
AND you can get it to run for as long as you are squirting fuel in....
yeap i get sparks, timing will do on the weekend as battery is flat again, leads are in corect order, cylinders ect, i can get it to fire as long as i spray fuel in it (not running)
then it sounds like fuel problem.. (but doesn't trule out dead compression)
big vacuum leaks? no gasket? hoses hooked up wrong? (pull all hoses off the manifold and carby and plug them to start?
i dont know where the vaccum hoses go & i spent hours today searching google & toyota forums & nothing...
sounds good, ill plug them all this weekend
hmm, when you rebuilt carby, did you change the "closed position" of the butterfly? it shoul dbe open like half to one mm, so that some air always gets in.
does holding foot slightly on the pedal make any difference?
or two pumps of the pedal before starting and then hold pedal down slightly?
i think i might of changed the closed position of the butterfly. there is the slightest gap when the butterfly is closed & i can hear the carby sucking air out the top when cranking. i have looked in both my manuals & there is only a initial setting for the air, fuel mixture, all the others are adjusted when the engine is running
no moving the throttle or choke does nothing, no i tried two pumps then crank & i think it fired then died (strange that it only fires when it wants to even when im pumping the throttle???
if you pump pedal/throttle, does some fuel squirt in from the accel pump?
