None without adaptors if you want to retain those struts.
You would need new rotors too, the RA23 rotors are not vented and too thin for any 4 pot caliper.
So factor that in too if you decide to try and retain the current struts.
hey i have already upgraded the front brake calipers, strut legs ,stub axles and brake rotors form ta22 items to ra23 items but i would like 2 bolt up some 4 spot brake calipers, do u know of any brake calipers that would bolt straight up to ra23 strut legs and stub axles and rotors.thanks
haha it would seem that im following YLD around the forums.
i know its not really what you asked but have you considerd AE86 struts? you can but fairly prices Wilwood big brake kits and would cost a similar amount to the corona strut conversion, apparently you can run 0 offset wheels without a problem on the se struts.
Otherwise like said abouve you will need adaptors and bigger rotors =$$$
hey sorry to just jump on the band wagon here but im going through a bit of the same process with my celica, so far ive managed to work out that ive got the ae86 discs on my front end, is there any way i can tell if the hubs and struts are also ae86?
