the pits will have that sort of information. When I did my 3sgte conversion, the guys at the pits give the engineer the standard engine info. so do the conversion get it engineered then mod it up. if it comes as a standard engine for that chassis you don't need engineer. your power must be within 25% of the factory standard. otherwise will definatly need engineer.
Use the internet it is your friend, you should be able to get all the info you need off of it.
