After a bit of searching and thinking, i think the camery v6 may just be a little to tall but i did fine another option 4agzte i had seen in the past a HKS kit to transform a gze to run a t3 for high end and supercharger for the bottom end of the rev range, boost controled to cut out the supercharger at the point where the turbo cuts in, so you get the best of both worlds. Has any one done this conversion, is it worth it or should i just stick with a 4agte
Found this quote on toysport:
The U.S. 4AG-ZE in the MR2 developed 140HP with the supercharger and with strictly bolt-on modifications produced 188HP. There was available a Twin Charger kit from HKS that developed 210HP and after further modifications produced in excess of 350HP! Also available was the HKS 5AG kit (not a Toyota designation), which included a stroked crank and over-size pistons for 1720cc.
any information will be greatly appreciated
Jason
i mean, a t3/4 is cheap as now, or even a t25.. witht he sc12..=)...couldn't you do it yourself though? only twin poiping into inlet manifold, just run a normal 4agte setup but leave super charger running through the turbo's intercoooler, then plumb them both into the same intake?? i think the opnly probvlem, would obviously treating a clutch system to the turbo and/or havuig the sc pull from say 1000rpm to 2850 rpm, then the turbo kicks in? thatd work i think...
