Results 1 to 4 of 4
Thread: How to drop an Mx83 Fuel Tank ??
    Junior Member Grease Monkey slydin-cressy-style's Avatar
    Default How to drop an Mx83 Fuel Tank ??
    Hi guys
    Im going to drop my fuel tank soon and give it a good clean out
    How do you go about dropping the fuel tank ??
    Also, whats the best way of cleaning your fuel tank ??
    My car has been sitting in the workshop for about a month and a half now and the fuel i put in it before it went into the shop was a few weeks old before that (so about 2 months old )
    I wish i had a workshop manual...
    Any info is great
    Josh
    SUPPORTING AUSTRALIAN PERFORMANCE PRODUCTS...
    TURBOSMART MICROTECH JUST ALLOY RADIATORS
    THANKS TO:
    - ALL TRANSMISSIONS - IMPORT AUTO PARTS
    - P.I.T.S - PLATNIUM AUTO CARE
    Jun 2008
    Default Re: How to drop an Mx83 Fuel Tank ??
    If you are worried about two month old fuel - forget it. It's not going to deteriorate in that time.
    Least it doesnt snore Backyard Mechanic Gary's Avatar
    hows the condition of your fuel filter? if its royally gummed up, i'd think about dropping the tank, but if its not too bad its a bit of a waste of time
    up to you though of course
    JZX83
    UCF11
    Breaker of all things aka Backyard Mechanic Chrisso's Avatar
    Vancouver, BC
    Another vote for not worth the time. However, if you feel the need to empty the old fuel, undo the plug underneath. If you're worried your tank might be dirty (which is unlikely), drain the fuel and see if there's any crap in it. If there is, then drop your tank and clean it. It should be pretty obvious how to take it out. Undo electrical leads to pump & sender - accessed through the boot; remove cover if applicable; undo straps holding tank in; let tank fall on head
    I put a pump in my 25yr old sprinter and the tank was almost perfectly clean. Just the slightest amount of crap on the bottom of the filter.
    Regards,
    Chris
    AE86 4 shades of silver - The Lone Ranger's steed is on the road again!
    AE86 shell - waiting for a donor car from the auctions.
  1. 1JZ Fuel Pressure Regulator Limits
    By beasht in forum Tech and Conversions
    Last Post: 19-04-2008, 05:17 PM
  2. Fuel pump & surge tank Size
    By rogue-vl in forum Tech and Conversions
    Last Post: 22-02-2008, 06:27 PM
  3. RA23 Fuel Tank Ins/Outs
    By Spectre in forum Tech and Conversions
    Last Post: 10-05-2007, 01:13 PM
  4. Replies: 1
