Results 1 to 5 of 5
Thread: Headgasket 7m-ge where to go in Sydney?
    Low rep
    Feb 2008
    Question Headgasket 7m-ge where to go in Sydney?
    Where to go for engine rebuild for a 7m-ge to replace head gasket?
    I'm in Sydney, NSW.
    Also... should i get bother getting aftermarket cometic headgaskets? Or just stick with a Toyota one, since its non-turbo.
    What parts are needed to do all this work?
    Nov 2007
    Default Re: Headgasket 7m-ge where to go in Sydney?
    mate google TSRM. that will show you all the steps needed to get the headgaskit out and more
    7MGE will be fine with a standard gasket, just get it re-torqued more than the original toyota spec. Something like 70 should be fine.
    Jun 2008
    I changed a head gasket a little while back.
    (1) retorque the head after about 600k as you will find the torques will drop off quite a lot.
    (2) I found the welsh plug behind the starter motor was leaking. Change the all the plugs and fit brass ones from Repco. 3 to 4 dollars each.
    (3) put a new set of brushes in the starter motor as its far easier to reach the starter and welsh plugs with the head off.
    Junior Member 1st year Apprentice turbo_gze's Avatar
    Theres a guy in Villawood whos heaps experienced with 7m's. Reckons he found a way for the head to last.
    His on Miller St same Block of units as Candyman just after the train tracks.
  1. 7m and 1g injectors?
    By hypo23 in forum Tech and Conversions
    Last Post: 05-10-2006, 02:28 PM
