Page 3 of 7 FirstFirst 12345 ... LastLast
Results 31 to 45 of 104
Thread: why NOT to put a 1j in a hilux.
    Default Re: why NOT to put a 1j in a hilux.
    sweet can't believe how much of a difference it makes..
    you bastard! making me anxious!
    QUICKEST 1JZ'S IN OZ
    im so keen to get it finished now..
    Junior Member Domestic Engineer 1200det's Avatar
    i posted it there without saying it was mine.. just to see what they would say
    hey champ,
    i say go for it!!!
    im in newcastle and i got a mate that did this and its there work truck!!!
    would go fast his did a low 11 quater
    good luck with it champ
    low 11's? how much work had he done to it? and why isn't it on the top 20?
  8. #38
    Sounds like Jamie's JT racing Navara to me.
  9. #39
    oh.. i assumed it was a hilux
    hmmm looks like i have to run 12's to get onto the list..
  10. #40
    Built! not bought Grease Monkey SYC02T's Avatar
    He is in that list allready with a 11.3
  11. #41
    another WHY to add to the list.. i did ~260km over the weekend, booting it a fair bit, and it returned 13L/100km
  12. #42
    sa
    Not too shabby. My gze seems to deliver 10 fairly consistently.
  13. #43
    the next tank was ~14.9L /100
    Another strange one has reared its head, related to the control of the auto, the shift into 3rd at full throttle is 'delayed' need to hook up our solenoid indicator lights, and see whether the trans is 'trying' to shift and just not, or what.. it feels like the computer is doing the 'retard for shift' thing, and its not shifting, doesn't feel as harsh as the issue we had before with it hitting the rev limiter hard on the 1-2 shift.
    It could be also that the ignition is breaking down.. going to chuck a set of plugs in it too, they probably have 100K on them.. sne.. its not driving at the moment, because i pulled it all to pieces to get the heater core fixed, and put a stereo in it.. hopefully have it going again tonight or tomorrow.
    ive also ordered my brake upgrade.. i'll try and take some pics when i fit it, its from hoppers stoppers in vic, 300mm discs with commodore calipers, they also do a 330mm version, i decided that might be overkill, and meant i couldn't run antything smaller than 17's.
  14. #44
    wanker Backyard Mechanic MS-75's Avatar
    Project is coming along nicely there. Good to see someone around here has finally done this conversion. Waaayy overdue.
    Is the hilux a wishbone or strut set-up, and does it run rack and pinion?
    Sean
    [email protected], WSID, COMPAK ATTAK, MAY 2006
  15. #45
    torsion bar whishbone setup i think, definately torsions, need to lower the back a bit and replace some shocks..
    currently i suspect our speed sensor converter signal is not dividing by the right amount for the second sensor.. it DEFINATELY has no speed limiter.. at least not where its supposed to be..
  1. changing the gear ratio's in hilux diff.
    Last Post: 14-10-2006, 01:41 PM
  2. Alloy Trays on Hilux/ Cruiser/ Hilux 4 door
    By Robbos_Toyotas in forum Tech and Conversions
    Last Post: 02-03-2006, 07:54 PM
  3. hilux caliper comparisons?
    By AE25 in forum Tech and Conversions
    Last Post: 05-12-2005, 07:04 PM
