Results 1 to 9 of 9
Thread: 4AC Removing the HEad
    May 2008
    Default 4AC Removing the HEad
    Ok so i'm replacing the Head on my 4AC, don't ask why but trust me that is has to be done, now i removed the timing covers, the belt, the Carby, the fuel rail, detached the section of the exhaust so just the headers are still attached, disconnected all atttached hoses and lines and the 9 bolts from under the rocker cover, now as far as i can tell it should now just lift off, i expected it to be stuck on good but either it's ten times heavier than the head off a 3S-GE or it's stuck down like a real bitch OR there's something else i have to remove, any ideas what i'm missing here?
    Default Re: 4AC Removing the HEad
    Theres 10 head bolts. Coolant lines also run into the head, and theres probably a brace between the back of the inlet manifold and the block.
    mechanic
    tas
    im pretty sure you will find that there is 10 head bolts to be removed not 9,beat me 2 it ^^^
    May 2008
    I count four in front evenly spaced and 5 at the back evenly spaced?
    EDIT* these are the ones i found!
    http://i284.photobucket.com/albums/l...DSC01006-1.jpg
    surely there is one in that gap there? they should be evenly spaced, 5 on each side. maybe it has different style head?
    Assuming all 4a engines run the same blocks (or close to) there will be 10. Probably need to remove the cam to get to it.
    Nov 2007
    Just a q, if you only need a runner, search the ae86 forums for spare 4ac's. They typically go for zero dollars.
    Hell, I have one in my shed you can take sans a few small parts.
    I'm in Vic.
    Jan 2008
    Maybe this engine has one stud missing.
    May 2008
    Default Re: 4AC Removing the Head
    ok so the reason i need a new head is that the three tappet bolts that hold the Cam down and your rocker cover down won't sit securely, during removal to replace the Cam gear that shattered, somehow the threads they go into got all screwy and they just keep turning and not tightening anything down, tried re-threading them and they popped out causing the arm above the cam (the thing with the rocker arms on it) to snap so rather than doing it again, replacing parts and taking the risk again, the old man just wants to replace the whole head.
  1. Building up a mean F head
    Last Post: 02-01-2009, 01:10 PM
  2. Removing / Inspecting valve springs without removing the head - is it possible?
    Last Post: 16-06-2006, 01:58 AM
  3. Removing cam gear
    By Ender in forum Tech and Conversions
    Last Post: 09-03-2006, 10:05 PM
