Results 16 to 30 of 37
Thread: 7MGTE into mx10 straight bolt on?
    Default Re: 7MGTE into mx10 straight bolt on?
    You could bolt up the original auto - it will last 20 minutes or so.
    If you use any other gearbox, you'll need to modify the gearbox cross member. As for tailshaft depends on which gearbox you use.
    Use a manual Corona Mk2 pedal box. You can modify an auto one I suppose - I'd consider using RT104 pedals but they may not suit. You're going to have to do the hard yards yourself there.
    I also want to see a 7MGTE sitting on the ground next to your MX10 and a fuckload less SMS talk before I contribute any further.
    Junior Member Grease Monkey da12nv's Avatar
    Jun 2008
    ok thanks guys im gunna go off wat all of u say so im goin to buy a 7mgte and it should bolt straigt in anything else some one wants to add to the conversion..mx13 diff ok for this
    p00 powar Grease Monkey Jin~Jah's Avatar
    the diff may last as long as the original gearbox will, depending on how you treat it
    i am a rollomatic Backyard Mechanic _gear2's Avatar
    New South Wales
    i belive i have all the manual parts that u require lying around off a manual Corona Mk2
    the pedal box etc.. (have a look if i can soure them up for u) but if u live up penrith way
    the wrecker on new line road has a manual mark 2 in his yard if i remember right.
    i feel much better now that ive given up hope
    Jun 2008
    thanks that will be a help
    Quote Originally Posted by gianttomato
    very next post:
    Quote Originally Posted by da12nv
    lol wtf u r a fkn spanner m8 >:/
    i pulled three hundred rocks from the land to build my house
    i walked quiet through the forest like a tiny quiet forest mouse
    the oceans will rise
    please stand by the shore
    Jun 2008
    wats a spanner?
    New South Wales
    ahh dear they have already started to neg rep u poor da12nv...
    doing any form of engine conversion is a relatively expensive and consuming process.
    You really should sit down and plan out this on paper first. Work out all the things you could ‘think’ you would need all the respective costs u believe are involved (then as everyone likes to chime in double it). Even though the engine will fit the same mounts its not simply ‘drop in’ turn the key and away you go. Like all fun things there is a lot of dickin around such as the funness of wiring and putting the intercooler plumbing in which with the 7mgte is a rather bitch.
    While you may find certain people on this forum blunt to the point of being hostile, these are people that have done and can do these kinda conversions. The problem is lots of people blurt out their ideas of a conversion but never put much besides their daydreaming minds into practice.
    The topic of engine conversions into mx13 and its similar brothers and sisters 22/23’s
    Has been covered in previous posts on both this and the old forum if u do some searching a few things will pop up
    best of luck! mate. though my best advice jump in the deep end see if u can swim and keep up with the mounting debt you get yourself in.
    peace
    Not in the diner Alf! Conversion King RyleyMA61's Avatar
    look up sam's 7mgte into ma61 conversion guid. it's very detailed and a very similar same process as you will have to follow for the mx10.
    Just buy motor, loom and ECU. We will guide you through it.
    Jun 2008
    motor should be comin next week..
    DA-12-NV
    We await pics or ban
    wats a spanner?
    i think an engine conversion may be beyond you
    okthxbie
    Jun 2008
    well c hahahaha
    DA-12-NV
    vic
    Quote Originally Posted by SeptemberSquall
    i think english may be beyond you
    okthxbie
    fixed......
  1. Bolt FAQ
    By dogeatdog01 in forum Tech and Conversions
    Last Post: 18-02-2008, 03:52 PM
