Results 1 to 14 of 14
Thread: 1 and 2JZ idle stepper motors
    Forum Sponsor Automotive Encyclopaedia dori dori's Avatar
    Default 1 and 2JZ idle stepper motors
    Hi, does anyone know if the 1 and 2JZ GTE idle stepper motors are the same?
    I need one for a 2JZ-GTE and don't know if they are interchangeable.
    Grant
    Fava beans and chianti Backyard Mechanic AE86slut's Avatar
    New South Wales
    Default Re: 1 and 2JZ idle stepper motors
    Get a 7M or a Nissan motor.
    I am not a doctor, or a mechanic...
    A.K.A Otomoto
    All new - Fart!
    Quote Originally Posted by Vios-GT_07
    it was 10,000 kms b4 it saw the red-line.. but even then i seldom push it that hard unless i have to prove a point i.e. competition
    Grant, you going to run an aftermarket ecu at all?
    Not much can control a toyota idle motor.
    New South Wales
    Quote Originally Posted by BlackSupra
    It will be running a Haltech. So if the Toyota one won't talk to it, what other options are there for the 2J?
    A.K.A Otomoto
    All new - Fart!
    I asked about what people were using previously and it seems that most people aren't using one. Just crack the throttle a bit instead.
    Alternatively, a simple 2 wire one that is programmed to open up to a certain temp or below certain revs should do the job.
    QUICKEST 1JZ'S IN OZ
    Haltech can control them. Unfortunately the VVTi 2JZ has idle control built into the throttle body which is also electric.
    I've since swapped over to an early style 2JZ plenum and throttle body but it was missing a stepper motor.
    Does anyone have one for sale?
    I have a 1jz one I think at home. If you find out if it is the same, let me know I have never seen the 2jz one.
    Junior Member Backyard Mechanic manny's Avatar
    I've got a spare 2JZ-GTE non-VVTi ICSV here.
    PM me a reasonable offer if you're still after one.
    1JZ-GTE and 2JZ-GTE ICSVs are somewhat different and not interchangeable.
    GSE20 IS250 - daily
    Quote Originally Posted by AE86slut
    Ford XF Falcon Idle Speed valve is the one of choice for Autronic users.
    So haltech controls VVTi now?
    Manny, i'll let you know in the next day or two if i need one. Cheers
    Blacksupra, the Haltech can control the idle motor very well (close to factory according to my wiring guy) and we will be working on the VVT-i control.
    I wasn't keen on the Ford unit as i want to keep it as clean (factory looking) as possible.
    Well before the twins go on that is.
    Cheers guys
    Grant,
    Keep us informed re the Haltech and the VVTi control. It would be a real shame to not be able to use it all because of the ECU choice.
    I was under the impression Haltech could switch a VVT set up but not VVTi. Pretty sure that is still only available with the Motec or Autronic SM4 Labels ???
    1971 2T-B Celica TA22 ST.
    1975 2T-G Celica TA27 GT
    1985 3F Auto FJ62 Landcruiser
    *signing up to thread* I too was under the assumption the Haltech couldn't control the infinetly variable timing, just the standard VVT switch stuff. I too thought only the Motec or Autronic models could control it properly. Will be interesting.
    cough"microtech dont need one"cough.
    cough"idles perfectly" cough
    8.3 et PB 169 MPH PB
    Its still early stages with the VVTi control through the Haltech.
    I'm more than happy to have Haltech use the car as an R&D mule.
  1. 1jz vs 2jz heads
    Last Post: 04-05-2006, 10:07 AM
