Results 1 to 15 of 30
Thread: 18r turbo
    Jun 2008
    melbourne
    Default 18r turbo
    hi to all i am new here to this forum.
    I am in the process of building a hilux rn41 turbo. The motor is a 18R which has most of the things done. i got the motor with the hilux when i bought it so all the hard work has been done .. Just wanted to ask if any one has done one 18R turbo up if they could send some pictures also i wanted to know how are these motors in performance wise.
    David
    Default Re: 18r turbo
    i have already done this - would advise against it
    -you have turbo and intake on one side so plumbing is a nightmare
    -the dizzi has no boost retard so you have ignition issues to resolve (you need high static timing for lower compression but this is the enemy of boost and locked timing makes it a poor performer)
    -a suck-thru turbo is the simplest to setup but you have no opportunity for intercooling so water injection is required
    -make sure turbo manifold is well braced otherwise that much weight hanging off 4 bolts will eventually start to sag and make gaskets leak
    If you can, change to an 18RG so you can get access to sensible EFI (and thus timing control) and you separate the intake and zorst.
    My site below has some pics of my setup.
    Jun 2008
    melbourne
    hi thanks for the responce i have allready done the hard yards my dizzy has been converted to electronic it has a boost retard on it a high energy coil the bottom end has got forged pistons crank work have done head work the cam is not standed the manifold
    has been already done have a after market fuel pump malpassi reg a cd175 carby with turbo jets and a lot more i will be posting some pics soon.
    i wouldn't bother with an expensive reg tho have to admit that the malpassi is good for carbi setups - being low-pressure carb, you'll want flow not pressure. I had a big/noisy carter pump supplying fuel from the tank.
    ... good luck with the motor - they're strong but run out of puff >5k (well, mine does). I went EFI and smaller (ex RB20 T3 ball-bearing turbo) so i could get boost earlier and not so violently.
    edit: having a proper turbo manifold (individual ports feeding well-designed collector) rather than a log manifold helps as well.
    btw: where are you taking the oil supply for the turbo? oil-filter housing or below the oil-pressure sender?
    Jun 2008
    melbourne
    im getting the oil feed from the oil pressure switch why do u think elsewhere ?
    Jun 2008
    melbourne
    all i want is some grunt in not trying to pull any times down the 1/4 mile more a fun car.
    was just curious about the oil feed - a few old-school 18RG guys i know are big fans of taking it from the filter housing, as in theory it's closer to the oil pump. My block came with another port below the oil-pressure sender hole so i used that.
    you'll find a big difference between the stock 18R and one with a hairdryer on it
    Mine went from 2 door slug to able to carry 4-people plus luggage yet be climbing at >160k (on a private rural road of course).
    Jun 2008
    melbourne
    Jun 2008
    melbourne
    Jun 2008
    melbourne
    cool not bad i think i will run it the same way you did.. ill soon post up some pictures for u all she is not much but she is my baby!!! how much power do you think i will get out of her
    Might wanna try and hunt down an 18rg oil pump as they flow a higher amount of oil
    bEn
    FJ40 landcruiser
    HJ47 landcruiser
    FJ55 Landcruiser
    MS65 Crown
    Gday,
    I contemplated doing the same thing to my RA28 "just cause I can", but sensibility got the better of me and I went with the 18R-GTE route.
    My only suggestion here, is you could improve it by changing the carb out for an EA foulcan CFI injection setup. The throttlebody should be plenty big enough as would the injectors, then you can run an oxygen sensor for feedback, and get something resembling fuel economy, and by programming the ECU properly, you can eliminate dead spots and protect against engine damage to a much greater extent. The MegaSquirt 2 ECU will be more than up to the task, and not cost much either.
    That's my suggestions (well the ones that don't say ditch it for an 18R-GTE anyway), but good luck with it, hopefully it should last you quite some time and provide the torque you require. Oh, a decent cam might be helpful too, maybe try Tighe cams in the greater Brisvegas region.
    Jun 2008
    melbourne
    Hi there people,
    I took some some photos today of my lux here she is....
    Thanks guys hope u like her. i will take better photos later on down the track with the tray on aswell and i will keep you updated
    very nice setup - old school but it'll do the job (and good skids)
    i'm assuming there's a waste-gate hiding beneath the turbo?
    and you're going to run some kind of water injection?
    note: you'll probably want another vacuum port ahead of the turbo so the brake M/C and PCV valve on the rocker cover never see boost.
    Looks pretty clean mate. I still think that carb could be replaced with an injection set.
    Last Post: 03-05-2009, 07:47 PM
  2. Tips for my high comp turbo gen 3 3sge
    By trd3sg in forum Tech and Conversions
    Last Post: 26-02-2008, 01:43 PM
  3. unusual turbo/ exhaust question
    By ae10 in forum Tech and Conversions
    Last Post: 07-05-2006, 06:27 PM
  4. Damaged turbo
    Last Post: 28-04-2006, 08:42 PM
