There are different gears inside the gearbox too.
10 and 11 teeth spring to mind, and I think there may also be a 12?
Also as another note there are smaller / larger 11 teeth internal gearbox gears (I think my experience was 11 teeth internal gearbox gears). With the smaller internal gear the 'external' gear is larger so that it still meshes.
The little white nylon gear that you insert into the gearbox has 10:32, which is internal:external teeth count, you could check both your gears to see if they are meant to have the same internal gearbox tooth count
