anything in the "spray painting" thread?
edit: http://toymods.net/forums/showthread...spray+painting
Ok...i've searched and read plenty of posts stating you can buy iso free 2 pack, but i can't seem to find too much about anyone actually using it.
I would like some advice from those that have actually used it and what they think of it![]()
Is one better than the other? Protec....Hichem?
Is it harder/ easier to use than other 2 pack paint?
Is the finish as good?
Do you think it will last as well?
Any other tips or tricks i should know?
I have previously used 2 pack with satisfactory results but am concerned about its toxic nature.![]()
My next job i plan to try iso free 2 pack COB metallic.
All advice appreciated.![]()
Glenno52.
1g-gze Corona RT132 (Daily)
RA23 Celica (Project under way)
RT81 & MS112 (Still Thinking About It!)
Wife thinks i'm mad (yep... she's right!)
Searched?
A couple of people (ae86tureno & ian from memory) have used it.
I have a can of Protec iso-free here, but havent used it yet.
Daily: Toyota '05 Rav4 Sport
hi glenno 52Originally Posted by MWP
most of the 2pacs are safe now
if you are only going to paint occasionaly you will be fine ,but if you plan on making it your career yes then i would be more concerned
if you use a good quality respirator you will be ok
dont forget to suit up as it also can be absorbed through the skin
you can buy the disposable suits for a few dollars
people who smoke are in more danger than ones that use 2 pac
ian
Thanks Ian. I'm a non smoker so I guess that will give me a head start.Originally Posted by ian
Seriously......Every time I am after information, I use the 'Search' first.
Sometimes I find what i'm after.....Sometimes I spend ages just going around in circles!
When I get too frustrated, i will then ask questions.
So...here I am!![]()
hi
if people did not ask questions ,it is a sign that they do not want to learn .grasshopper
lol
i didnt mean to suggest that you smoke
it was only a comparison , maybe a better way of putting it would be that it would be no more harmfull than exhaust fumes in an underground car park
Wouldn't be worried about suggestions anyway Ian...skin is too old and thick. I know you were only giving an example.Originally Posted by ian
So, when you say 'good quality respirator', what sort of $$$ do you have to spend?
I probably only paint one car every two years on average, so i can't justify spending $500 on professional gear.
I'll be painting in a large open shed with good flow thru ventilation. Oh, and don't worry about the neighbours. The nearest house is 5 kilometers away.
Glen.
hi glen
i picked up a pretty good respirator for $60 it has the replaceable twin charcol cannisters
if you have a leaf blower blow out all excess dust the day before you spray
prep you car
put an earth strap on it, wet the floor so you wont kick up any dust , and away you go , easy as
the disposable suits and a box of solvent resistent gloves should cost no more than $20
however the beer consumed when finished can be expensive
ian
it'S not good to have the stuff harden in your lungs so resp is good
some people don't bother but.....not sure i'd wanna be coughing up 2pack to get it out of my lungs![]()
From professional experience, iso free 2k clear is much harder to use than iso 2k clear...Originally Posted by Glenno52
You have to spray it on a lot wetter/thicker to retain a nice gloss, which gives more chance of runs, but the end result is usually a deeper gloss...
Practice, practice, practice...
First of all though, I'd wan't to know why you have the requirement to use an iso free 2k?
My understanding is that the EPA doesn't allow spraying of ISO 2pack in ones back shed...Originally Posted by twentyEight
That's completely correct...Originally Posted by wilbo666
I missed the large open shed bit, which was why I was asking him what his requirements for using iso free 2k were...![]()
You will definitely have to use (legally) an isocyanide free 2k in your case...
I wanted to ask some q's about the same thing, they've been answered.
i'm in the middle of stripping my car for a paint job ....
however i did the rounds on the phone, Dupont is another brand the does iso free 2k
i don't know what dupont is like, will be getting a sample tin in a few weeks.
one thing i thought was probably not a good idea. done a fair bit of painting my self.
wetting the floor in a shed is not a good idea, because paint is moisture curable,
as the water is evaporating or any humidity, going from the floor into the air will go through
the spray mist from your gun. as you pull the trigger, the temperature of the paint drops,
sometimes significantly and this i thought could make the paint dry before it hits the panel.
any thoughts on that ?
yes in theoryOriginally Posted by mike1980ra40
but the good spray booths like seeta have water traps mostly underneath the floor
you will get more moisture in your work by not having a dedicated moisture trap in your air line
or even worse painting on a humid day
2 pak dries from the inside out by chemical reaction . Acrylics dry from the outside in,its the solvents evaporating that dries it
with the spraying
if the paint is put on dry that is not enough reducer [ to thick ]
it will go on dry
have a look through the articles by peter from infotec that may explain more clearly than i have
ian
Only thought of using it to reduce inhaling toxic fumes.Originally Posted by twentyEight
So you think i'd be better off using normal iso 2Pac, considering i have an open shed and no neighbours?
Glenno52.
