Results 1 to 15 of 24
Thread: 79 corolla 4age
    Jun 2008
    south australia
    Default 79 corolla 4age
    hi people,
    i have just been given a 79 corolla with a 4age (not fitted at present ).the motor was removed to replace the solex carbies for efi but 1/2 way throu the wire of the computer the prevous owner decided not to finish it for some reason. im thinking of running some 40mm or 45mm webers or putting the 20 valve version in what is the best option?? please give me some ideas on witch way to go. keeping in mind that the car has been sheded for 8 1/2 yrs so im going to have pull the 16 vavle motor down if i am to use it ( i got 2 4age with the car and the carbies were given away) also what mods would you suggest i do to the motor while i have stripped down (ie cams etc) ?
    sorry for the long post !!!!! andc thank you in advance for any advice given to me!!!!!
    as it has been 10yrs since i have played with any modifed cars but im keen to get this corolla back on the road
    Default Re: 79 corolla 4age
    EFI will be better than carbs for day to day, and, as a bonus... can be made legal.. as opposed to carbs (then again, anything goes in SA.. until you get caught)
    strip, clean or rebuild the 16V, whack it in with EFI and go have fun
    Jun 2008
    Wow, you were given two of these! You're a lucky man!
    Jun 2008
    south australia
    can i use the efi off the 16 valve that the in take faces the firewall or quad throtle body off the 20valve version(which i dont have)???
    Jun 2008
    south australia
    grotty it going to be a lot of work needed to get it back to it former glory but im up for the challenge
    can use the 16V intake, get a plate welded to other end to face forwards. done many times.
    the ITB's can be done and there are off the shelf adaptors, but to get the best of it, need aftermarket ECU?
    at first go the 16V intake... perhaps?
    Jun 2008
    south australia
    if i go with 16v efi will i need a new ecu if go for a bigger set of cams and mild cleen up of the head? ps does anyone know of somebody in adel who can do this for me .or can some post a pic please? thanks in advance!!!
    My Missus is a Domestic Engineer BradW's Avatar
    Have a read of Bill Sherwood's site. It will tell you everything you need to know about 4age's. Phil Bradshaw's site also has lots of good info. Also search on here and the old Toymods forum as there is plenty of info on this subject.
    What type of 4age do you have. If it's a bigport, you can use a rwd manifold. If it's a small port you can buy an adaptor from techno toy tuning in the states to bolt the rwd bigport manifold on or you can cut and shut the smallport manifold as oldcorollas suggested.
    I would suggest to stick with efi as well. The other problem you will have with running the carbs is sorting out an ignition system as the factory ignition on these runs through the ecu. I have read some threads on here about it so have a search.
    Good luck and stick with it. Done properly it will be a fun car when it's finished.
    Brad
    Old Corollas never die...
    My KE30
    Jun 2008
    south australia
    brad im un sure of if its a bigport or sml port it has a silver cam cover. the ignition has been modified for carbies as that is what it was running before. my mate whom give the car to me used it everyday for four years but then moved o/s and was trying to efi conversion just before he left 8 1/2 yrs ago never to be finished. thats why i tought webers would be easyer to do but i do have all the efi stuff there. it was a fun car to drive back then thats why im so excited about getting my hands on this !!!!!! no doubt ill be scaning all the threds on toymods for all the help i can get thanks
    Jun 2008
    south australia
    is there anyone in adelaide who i can go and speak to about 4age info??
    thanks for the info so far guys!!!!!!!!!!
    if you are thinking of using 4age 20V quad throttle bodies with you EFI setup there is a place called Techno Toy Tuning that sell an adapter that allows you to use them on the 16V heads. Here is the link http://www.technotoytuning.com/productdetail.php?p=372
    I also have an ignition module (aftermarket) that allows you to run 4 individual coils and uses a CAS (crank angle sensor) when using carbies if interested. ie. it is a standalone ignition module. But I would go for EFI if I was you
    Jun 2008
    south australia
    the wiring of the efi is scaring me me bit lol and im very familer with webers as i had them on a mk1 cortina with a 2ltr that i built along time ago but it could be time i steped up into the modern era
    Jun 2008
    south australia
    now looking for carbies set up for 4age plz help $$$ waiting as some one tryed to cut and shut the efi intake which is now f@*ked!!!
    Jun 2008
    south australia
    bump to the top
    Last Post: 17-06-2008, 08:53 PM
  2. 4AGE 86KW TVIS V 100KW 4AGE + Shocks
    By GeeEss in forum Tech and Conversions
    Last Post: 17-01-2007, 08:51 PM
  3. 20v 4AGE into AE92
    By dale_8888 in forum Tech and Conversions
    Last Post: 16-12-2005, 04:51 PM
