do you have spare glass just in case?
usually it is one or the other.. cut the seal and save glass, or break glass and save seal.
you can get buddies to sit in back and put pressure on glass with their feet 8two ppl better to give more even pressure), while you try and peel back and manipulate the lip of the seal..
it is not an easy or fun process, and less fun when the window breaks....
edit: it wasn't silicon sealed in was it? in that case you have to cut the silicon first.. thin metal wire threaded thru and pulled around the edge of the glass can work.. eventually... careful of the fingers
