Results 1 to 6 of 6
Thread: Fuel pump wiring.
    May 2007
    victoria
    Default Fuel pump wiring.
    Ok, ive gone and confused myself
    Ive finally found some time to spend on my celica and im up to wiring the fuel pump.
    Now its just currently on a switch just to get it running which i want to get rid of for obvious reasons.
    Engine is a 1ggte gen 2
    I have no idea how to start or what to search can any one point me in the right dirrection of how to wire this up.
    Jun 2006
    Default Re: Fuel pump wiring.
    you should be able to get a trigger for a relay from the ignition barrel
    get the wiring diagram so you can find fuel pump relay trigger from the ecu. then you run that wire to a relay, and wire your fuel pump through the relay. too easy.
    Use a Circuit Opening Relay
    See the below thread!
    http://www.toymods.net/forums/showth...+opening+relay
    May 2007
    victoria
    Quote Originally Posted by fandio
    Not running it off ignition, its all switch operated.
    Thanks for the info im going threw my wiring diagram now.
    Flapper AFMs have a switch for the fuel pump, look there first.
  1. Diagnosing a dying fuel pump
    Last Post: 01-04-2008, 05:45 PM
  2. Fuel pump wiring.
    By celupra in forum Tech and Conversions
    Last Post: 02-03-2008, 03:52 AM
  3. Replies: 19
    Last Post: 03-07-2006, 08:34 AM
  4. Mounting fuel pump (intank)
    Last Post: 24-01-2006, 09:49 AM
