Results 1 to 14 of 14
Thread: Problems with Fuel cut 2j
    Junior Member Grease Monkey minimechanic's Avatar
    Default Problems with Fuel cut 2j
    hey dudes
    i've got a hks fuel cut in the cressida..but it still hits fuel cut..
    could this be due to the wastegate being too small with the 3inch exhaust/highflow turbo's..?
    cheers dudes!
    lucas
    User Conversion King
    NWA
    Default Re: Problems with Fuel cut 2j
    if you have a fuel cut defender then it shouldnt 'hit fuel cut' regardless of boost.
    my homemade FCD avoided fuel cut even above 20psi (by accident).
    hello
    wa
    Like you said its probably due to overboosting caused by the wastegate being shit .
    If you put a restrictor ring in the exhaust the problem should be better i think 2/12 -2/1/4 is about right
    restrictor ring in the exhaust? mmmm dont really wanna restrict the exhaust any more cus that would be a loss in powah :'(
    anyone had experience with this before?
    A 2JZ with a custom dump pipe will need a restrictor to prevent boost creep. I needed to do it in mine otherwise boost would keep going up and up.
    This is a separate issue to fuel cut though, if the FCD is working you should not be getting fuel cut no matter what.
    maybe its fake rev limiter?
    if you have the fcd wired in properly you sholdnt get any fuel cut.
    if its fuel cut then you will get the engine light flashing when it happens, if its fake rev limiter you wont.
    fake rev limiter can be solved by using a jza80 ecu.
    you will need a restrictor, look in my members rides thread i used a restrictor plate rather than a modified zorst, so i can take it out when (or if) i get the wastegate problem sorted.
    nah no engine light flashing happening..
    i'll try using another ecu then...
    i'll check out ur members ride thread
    ++ rep!!
    the other thing you can do is unplug the tps and take it for a drive.
    i think the car will stay in first, but you can give it a good rev and if its the ecu fake rev limit, it WONT happen with the tps unplugged.
    cant think of what else it could be though....
    Forum Sponsor Automotive Encyclopaedia dori dori's Avatar
    Hey Lucas, you could always by the HKS computer i have for sale
    http://www.toymods.net/forums/showthread.php?t=36234
    Grant
    no money sorry grant
    taking the tps out wont damage the engine at all??
    Join the club.....
    Quote Originally Posted by minimechanic
    no i did this in my car, it just wont change gears
    Quote Originally Posted by PlacentaJuan
    can you still shift it manualy? ie 1st 2nd D?
    ืno i dont think so
    it will think the throttle is closed the whole time or something?
    anyway its just a quick test to see if thats the problem.
    actually maybe it will change, i cant really remember i just took my car for 1 quick run to see if it fixed the problem, i didnt really play around with the gears, but all i can remember is that i wouldnt put up with driving without tps.
  1. Turbos 101
  2. 2TG Turbo Upgrade - Advice/help please
    Last Post: 22-01-2007, 11:12 PM
  3. Fuel smell under boost/cruising mz20 7mgte
    By Kedderz in forum Tech and Conversions
    Last Post: 19-01-2007, 08:51 AM
  4. Swirl pots, how to and how not to
    By Billzilla in forum Tech and Conversions
    Last Post: 18-01-2007, 10:37 AM
  5. weak fuel pump? (1jz-gte lost alot of power)
    Last Post: 23-01-2006, 09:14 PM
