Yeah sounds like they supplied you with 1ggte mounts.
You do indeed need the steel pressed mounts and they look like this
http://lameda.homelinux.org/photos/C...sidemounts.jpg
They'll bolt to the front position and to your rubber mounts and crossmember.
It took me a while to find mine. If I was you I would just reweld mounts on your crossmember. The motor will sit lower and in the correct position plus if you can do it yourself you'll save money and time rather than hunting for the correct mounts.
stidnam
.. wheeled it over to the celica ra28.. grabbed my supposed non turbo engine mounts and discovered they look exactly the same as the standard turbo engine mounts off my motor
.. i ordered these through a jap importer who got them in and i hadnt actually got my half cut yet so i didnt know if these where the right ones or not.. today i went to test fit the motor and it didnt even come close to lining up to the factory ra28 engine mount positions.. does anyone have any photos of a non turbo engine mount for a 1gge? that i can have a glance and see how they line up differently??? really need some info.. once the motor is test fitted and all intercooler pipes are done and mounted then i can send it away for paint!!! im so painstakingly close to finishing this project!!!!
