Yeah sounds like they supplied you with 1ggte mounts.
You do indeed need the steel pressed mounts and they look like this
http://lameda.homelinux.org/photos/C...sidemounts.jpg
They'll bolt to the front position and to your rubber mounts and crossmember.
It took me a while to find mine. If I was you I would just reweld mounts on your crossmember. The motor will sit lower and in the correct position plus if you can do it yourself you'll save money and time rather than hunting for the correct mounts.
stidnam
