Mine gained like 7hp on the same dyno, albeit i was getting 1.5psi more the second time around
only person i know to have dynoed before and after ont he same dyno lost a couple of hp
that could be dure to temps etc though
its not worth it unless you already have it apart
yea was told that there would be HP loss from doing this.. not sure about torque.. can anyone confirm that using bigport cams in a smallport engine is pointless and causes power loss?Originally Posted by Mr Revhead
works well on 4agte motors , kicks in harder and pulls all the way to redline harder recommed it to any one for cheap power upgrade
these are the cams im now looking at.
CT271/272
411A
Slight lope at idle, good mid range power, suitable for std or slightly modified engines.
RPM RANGE 3000-6500
ANY
cam timing 25-65 65-25
advertised duration 270° 270°
[email protected]" 220° 220°
valve lift ×312² ×312²
lobe seperation 110°
running clearance ×010² ×012²
any opinions, i want to run these with the factory ecu.
1989 white supra 7mgte manual
http://www.toymods.org.au/forums/for...pra-turbo.html
should have mention this was an N/A engineOriginally Posted by takai
Yeah, the GZE probably woudl have liked the bees dick extra lift.
