Results 1 to 5 of 5
Thread: 2jz-ge map sencer
    Triptek Enhanced Backyard Mechanic triptek's Avatar
    Default 2jz-ge map sencer
    I was wandering if anyone could tell us if a 1jz-gte map sencer would work on a 2jz-ge motor.
    1994 GZX90 Mark II 1GZ-FE V12
    Xistant
    Guest
    Default Re: 2jz-ge map sencer
    sensor
    so 1jzgte sensor on a 2jzge? if so no it won't work.
    Nope, NA and turbo sensors have a different pressure range, for obvious reasons.
    The map sensor on my 2.2litre camry motor plugs in although I have never tried to run it with same
    Jealousy is a curse
    User Conversion King
    NWA
    you could always use something like a 1JZGTE map sensor and scale the signal electronically.
    but im sure there is many NA toyota engines that have compatable sensors
    hello
  1. 1JZ > 2JZ Map Sensor Upgrade Myth Burried.
    By JZA70 R in forum Tech and Conversions
    Last Post: 14-11-2008, 08:45 AM
  2. 1JZGTE ISCV & MAP Sensor Questions...
    Last Post: 11-11-2007, 04:52 PM
  3. delete me
    By EldarO in forum Tech and Conversions
    Last Post: 14-04-2007, 09:53 PM
