Very nice job. Is this a bigport of a smallport head (unsure if they are the same volume in the combustion chamber).
As per TRD spec........
Original combustion chamber volume (pics on top) between 36.25 cc to 36.5.0 cc. Finished combustion chambers between 37.00cc and 37.25cc. That is about a 2% difference. It is also important to note that this head has yet to see a milling machine.
this happens to be a smallport head... but everything I've ever been told says the combustion chambers never changed on 16V 4AGEs
And the point is... better flow, less CR?
Please show the transition from the seat's 45 to the head's alum., without the valve.
Thanks.
Much improved flow... the penalty was .75cc(3/4 of 1 cc), or less than 2% increase in volume. The ability to run substantially more compression with much less chance for pre-ignition since the sharp bits have been removed and polishedOriginally Posted by allencr
The 3 angle valve job has not been done yet,
Here might be a better photo showing the advantage of removing the shrouded section - this was my "practice head"... no work was done to the seats... this head was used for demonstration only
The above photo shows the valve at 7.4mm lift and 2mm lift
When you deshroud the valve(area around the valve), there is little if any step the air has to flow around....
ah the old deshrouding trick. I am about to do the same on my 7afe engine
good work by the way
thats a fairly decent trick is that de-shrouding idea...
how would a polished area in the combustion chamber there help with flow?
thinking about the 100kw pistons they are raised in that centre section i'm wondering if the polishing has anything to do with the resultant flame front at combustion time ; ie; removing all the dags/burrs etc helps with a more consistent flame...?
i don't know much about heads ect (except for where to take it to when it needs reco) so this is all quite interesting![]()
oldeskewltoy,
Can you post a link to where you found that info please. I've Googled myself silly and can't find one - I'm looking for similar info for the Silvertop 20 valve.
Thanks in advance.
Rick Jones
Cheers ..... Rick Jones
Fraser Clubman
the 16V info's in the "TRD Bible", it doesn't have the same sort of info for the 20V.
http://cgi.ebay.com.au/COROLLA-LEVIN...QQcmdZViewItem
looks pretty good
somethign i have wondered ever since reading the L&T bible
what the shit is a joggle?
also, only the bigport stuff is translated to english from memory, the smallprot and 20 valve info is all in japanese, and from memopry it is a bit light on fot the 20 valve engine.
I'd be quite interested to hear info on the 20V too, i haven't found much at all in my travels around teh interweb either.
Toymods Club Member
shinybluesteel...........i can only think a joggle is that section of the head/chamber?
only joggling i've come across was a tool to do something with panel work...
take a better pic of the japanese characters above where it says "joggles" on the diagram?
stu it probably says joggles in japanese mate![]()
I'm thinking perhaps 'ridges'?
