Results 16 to 20 of 20
Thread: speedo cable problem
    Default Re: speedo cable problem
    will find out today
    i checked today and there is 5 in the gearbox and 32 on the speed sensor or what ever it is called is that right or did i stuff something up?
    You stuffed up lol
    There is no way there is 5 on the inner gbox gear
    You need to mark one 'tooth' and then rotate the gobx output shaft until you get back to that tooth... should be 10 or 11
    You might have been confused as the teeth are on an angle...?
    haha shoot i will have to look at it 2morrow again.
    if there is 10 in the box and 32 on the speed sensor is there a reason its not working??
    You stuffed up lol
    Quote Originally Posted by frk5how
    The different sized gears available that I've mentioned before!
    I.e. there are larger / smaller 10 (11?) tooth inner gears, and the gears that mate with them change in size accordingly...
  1. How to fix your Jumpy Speedometer
    Last Post: 13-10-2006, 06:58 PM
  2. you can light up your speedo with LEDS
    By puzzle man in forum Tech and Conversions
    Last Post: 21-03-2006, 10:34 AM
  3. Speedo and Odometer questions
    By Big T in forum Tech and Conversions
    Last Post: 04-12-2005, 05:43 PM
