Results 1 to 8 of 8
Thread: toyota EL30 corsa, Good ~ Bad, Ugly?
    Low Down Style Domestic Engineer Johnzoku's Avatar
    queensland
    Default toyota EL30 corsa, Good ~ Bad, Ugly?
    just wondering if anyones had any experiance with these things? EL30/31 corsa/corolla GP/ tercel? ive seen a few around for sale and one in person and i quite like the look my sefl (espically the two tone black/grey) and would love an ep71 but i dont like my chances of finding a stock one.
    knowing theres a welth of info on the engines and ive read places that the ep71/82 starlet suspension slots in (unconfirmed tho) is there any unique problems with these? how do they handel etc...
    sorry but ive only started looking it to these so i havnt completly searched this topic just yet, but there wasnt much on toymods.... back to google!!!
    good link for specs.
    http://www.cars-directory.net/specs/.../corsa/1988_5/
    Exterior dimensions (LxWxH), mm 3910 x 1635 x 1370
    Interior dimensions (LxWxH), mm 1795 x 1400 x 1155
    Wheel base, mm 2380
    Treads (F/R), mm 1385 / 1355
    Ground clearance, mm 160
    Curb vehicle weight, kg 910
    Gross vehicle weight, kg
    Seating capacity, persons 5
    Doors number 3
    Min.turning radius, m 4.7
    Fuel tank capacity, l 45
    Displacement, cc 1456
    Engine model 3E-T
    Max.power (Net), kw(PS)/rpm 115 ps (84.58 kw) / 5600 rpm
    Max.torque(Net), N*m(kg*m)/rpm 17.5 kg*m (171.62 N*m) / 3200 rpm
    Power density 7.91
    Engine type Water cooling serial 4 cylinder OHC12 valve turbo
    Engine information Horizontal ranging
    Fuel system EFI-D (electronic fuel injection) (electronic gasoline injection)
    Turbocharger Turbo
    Fuel type Unleaded regular gasoline
    LEV system (Low emission vehicle) No
    Compression ratio 8
    Bore, mm 73
    Stroke, mm 87
    Fuel consumption at 10-15 modes, l/100km 6.7
    queensland
    Default Re: toyota EL30 corsa, Good ~ Bad, Ugly?
    has anyone had any experiance with these?
    im a fan of shopping trollies with pop up head lights
    I've never even heard of a Corsa.
    Is this what your thinking of?
    queensland
    bingo!
    its the gap between the starlet and the corolla.
    this is the bigger brother to the EP71 im pretty sure.
    I don't want to be a Domestic Engineer bnicho's Avatar
    Sorry, no experince with them, but I like them!
    Brett Nicholson (bnicho) - Greendale, Victoria
    I own Corollas, Crowns, Prados and
    Various leaking British things...
    they are basically a Tercel chassis, no?
    for a small car i reckon they look ok, and not so common.. but iut is stil lfwd shopping trolley. no idea on specifics of handling, but it is probably safe to assume "poor" and work from there
    if you are upping power, it might be good to find out what gearbox and driveshafts it eats
    queensland
    lolz... apperently there pretty strong from what ive read so far... but again "unconfirmed"
    im assuming it will be on the same basis as the EP71/EP82 so theres a couple of them around the place being wrecked im sure. they run the 3FFTE so motors wont be to hard to find but what are the internal parts like to purchace?
    yeah, same chassie as the trecel, i think trecel was the american name while japan called it the corsa... also this has some relationship to the paseo as well... i think there el43's no?
    had a look thru the AU starlet forum and theres not much on them either... strange...
    apperently there was only 6000 corolla Gp/ corsa turbos ever made so i guess thats why info is a bit hard to find
  1. Front Shock Absorber Dimensions...
    Last Post: 18-10-2005, 01:58 PM
