Yes MA61 rotors and calipers will bolt up to the RT142 IRS rear arms
I have RT142 rear arms in my MA61.
Was going to buy some new Rt142 rear rotors and was told by my local supplyer that these intems were no longer available.
So i was going to change them to MA61 rotors and callapers.
Cant seem to find to much info on this so i'm assuming it all bolts up?
Cheers Case
I was told today that only the IRS rotors are no longer being made, The live axle rotors are still around.
"Yes" year of RT142...???
RT142 1985 live axle.. Rear rotors # PBR 706, Rear pad's # DB 1098..
RT142 1986 IRS.. "no longer made" MA61 & MX73 rotors & calipers, may fit..???
Project: '82, GA61 XX
RT142 with IRS don't know the year anyway got some calapers on the way and some
MA61 rotors on the way.
Going to have a go as per Wilbo666 post it should bolt up.
If you need MA61 rotors and calipers, let me know...
Are they all the same size , i recall my MZ12 having larger rotors than the A61.
Dave
As far as i know RA65,SA63,MA61,RT142 and MX73 all share the same IRS sub frame altough the brake set up vairys along with the diff either T or F.
Don't know anyting about the MZ12 at all. Have a look in the DBA catalog.
Cheers Case
JDM / import stuff is different...MZ12 falls in the different boatOriginally Posted by cambelt1
I just went to put the MA61 rotors on and i can't get them to fit over the hand brake shoes?
The hand brake is off and wound right in.
The id on the RT142 rotors is larger the MA61 rotors?
Case
Not sure on IDs... (have you measured?)
But MA61 handbrake shoes work with MA61 disks...(and will fit to the RT142 rear arms fine).
I'm a bit surprised they are different, but measuring RT142 vs MA61 should clear it up...
Ive since worked out that MZ12 and MA61 and MX 73 all have different rear rotors and callipers . We wonder why toyota do these things.
MX 73 has th largest of the 3 .
Dave
