Results 16 to 17 of 17
Thread: Re: 20v with hiccups
    Default Re: 20v with hiccups
    Unless your original fault is very intermittent i'd be trying to sort that first, the spd signal is hurting nothing apart from the last 400rpm on your rev limit.
    If you are looking for something to do it is the purple and white wire running from your dash cluster down to the 12 pin plug in your ECU.
    Toymods Club Member
    Apr 2008
    n.s.w
    Okay since changing the plugs from BKR5E-11 to BKR6EP-11 the problem is not so bad and not as often. I'll try checking ignition barrel and go from there.
