Page 1 of 4 123 ... LastLast
Results 1 to 15 of 47
Thread: BOV which is best?
    Junior Member Grease Monkey crostek's Avatar
    Question BOV which is best?
    I am in the market for a blow off valve for my 18RG turbo motor.
    What is the best type / brand ?
    what would be the best size to suit T03/04 hibrid turbo (350)hp?
    thanks
    Shane
    Default Re: BOV which is best?
    Bosch Recirculating Air-Bypass Valve to suit a Porsche 911 Turbo
    Junior Member Carport Converter 4agte's Avatar
    aparantly the stock r33 gtr blow off valves are quite good and seeing as tho alot of gtr owners ditch em for aftermarket ones should be a few floating arround
    almost any aftermarket BOV will support you turbo. But the question is do you one that vents into the atmo, (illiegal according to epa and poilice) or one that vents back through the intake?
    ~MR2 GT with a big arse turbo + a 3sgte built tonka tuff = lota Fun~
    Who da F%^k is Takumi?? Backyard Mechanic 45aken's Avatar
    thats it,
    you could go and get yourself some masive 50mm BOV, but just about any quality one on the market (turbosmart, GFB, and anything jap) will do fine.
    but if your looking for a cheap bosch type, then i'd be looking into the 911 turbo one.
    the differences between atmo and plumback are neg (performance wise) the only thing is the ecu doesn't know whats going on when the atmo bov opens (at least with a motor using a AFM)
    AE86 - coming soon to a quiet mountain pass near you...
    WRX - currently epa'd...
    I'd be assuming given it's a custom turbo application you won't be using an AFM. That said, I'd still be going a recirculating one out of preference and for legal reasons.
    Junior Member Backyard Mechanic sw20r's Avatar
    Very True what JCMF says.
    Best to stay with oem type. As Turboshitmart, GFB and whatever are piston type bov's made in China quality that run springs to set pressure. if you were to get a venting one HKS and SARD is the closest to OEM design.
    my 3sgte has a AFM and i have a venting BOV and it has no problems wat so eva, i guess i must be lucky
    Quote Originally Posted by Jorrs
    I don't know about you dude... but this sounds like a problem to me..
    hey guys sometimes my car backfires. from 2nd to 3rd gear, it happened once when was under a bit of load i was giving it a fair bit into 3rd ? anyone no why this occurs ?
    It's what happens when you run a atmo venting BOV on an AFM motor.
    SHE LIVES!
    Not running air flow meter just quad throttle body with air box over them.
    but may have to use plumb back for EPA test.
    Isn't GFB made in OZ there are here in sydney?
    for cost I was going to spend up to $200.
    Frontyard Programmer Backyard Mechanic davedave's Avatar
    New South Wales
    lol, owned.
    Yep, when your computer is adding the correct amount of fuel for your metered air, and you're letting out some of your air, you're going to run rich every time.
    I run a bosch BOV myself and it's perfect for my application. The only thing I hear is my turbo spooling up sucking air, no flutter or psssssh. It's also black and nondescript and the best thing, it was only $60 from repco.
    I've heard the bosch though are only good for a limited amount of PSI (about 15PSI), then they start bleeding the air. So if you're after 300HP from your 18RG, I think you'll be pushing those limits.
    Which is why I suggested the 911 Turbo version
    Quote Originally Posted by Yian
    i got my injectors cleaned, and after that hasnt backfired at all
    Quote Originally Posted by davedave
    ferals one leaked at 10-12psi and i think someone else on this forum had one blow apart
    so running a venting BOV on a AFM car doesnt make it backfire must of been the injectors
  1. BOV on 4AG-ZE (seriously)
    By Ben Wilson in forum Tech and Conversions
    Last Post: 04-04-2006, 10:20 AM
  2. 1ggte bov
    Last Post: 22-02-2006, 09:32 AM
