much cheaper to do it yourself
4wd shops will have a kit or you could go to an auto sparky and get them to do it for you
unless you got a fully sealed battery you are required by law to vent the battery to the outside of the car.
easiest way to do it is run a cable from your +ve terminal to your starter motor +ve and then a thicker gauge wire from there to your battery (gauge required depends on length ie. voltage drop)
