Results 1 to 4 of 4
Thread: Carby problems
    Sep 2007
    Default Carby problems
    Hi
    I have a RT40 Corona with a 2r and a aisan std carby. It has had a Gaskit kit put through it.
    The problem I am having is that at light loads and about 2500rpm it feels like lean surge. I had this problem before the kit was put through it. The motor is standard.
    Any one have any suggestions on how to fix the problem?
    Default Re: Carby problems
    There isnt much you can adjust on a standard carb.
    The only adjments they normally have are idle speed, and idle mixture both of which wont help you.
    Are you sure its not ignition timing?
    Ignition not advancing far enough can cause a leaning out feeling.
    Check the vac advance (if it has it) and that the weights in the bottom of the dizzy can move freely.
    Sep 2007
    I don't appear to have any other issues but will check that again.
    I didn't think there was much i could do.
    Thanks
    Sep 2008
    Quote Originally Posted by 67Corona
    Hi
    Hi I am a ":retired" Motor mech spent many yrs onToyota ,if you slightly "ream " out the main jet [primary ] you should fix the problem ,using a jet drill of course worth a try ,Terry Murphy
  1. 4K-C carby query
    By WA_TRD_83 in forum Tech and Conversions
    Last Post: 26-03-2007, 02:01 AM
  2. 2t-c Stock carby problems!!! (just rebuilt carb)
    By 77GZE in forum Tech and Conversions
    Last Post: 05-03-2007, 08:25 PM
  3. 18RGU Carby and Cam Questions (long winded and a few pics)
    By floppy in forum Tech and Conversions
    Last Post: 07-01-2007, 12:25 AM
  4. 2T/ 3T carby
    By suss_slide in forum Tech and Conversions
    Last Post: 25-08-2006, 11:11 PM
  5. Problems solving 4agze
    Last Post: 28-06-2006, 07:21 PM
