is this a FWD or RWD setup?
where do you have the breather from the rocker cover plumbed? have u a cut and shut manifold?
theres a common issue when people do a cut and shut manifold they plumb the breather from the rocker into the inlet manifold port (i did this years ago) - the problem is this pressurizes the rocker and may be pushing oil past the seals down into the cylinders (especially as you motor is turbocharged)
another thought is when you re-did your bottom end, was the ring end gap within the correct spec as termed by toyota?
here : http://www.toymods.net/forums/showthread.php?t=88
read the section on NOTE : RE PCV HOSE (thanks karl/jason purcell for this article)
hope this helps mate![]()
