Results 1 to 6 of 6
Thread: help with steering
    Sep 2007
    Default help with steering
    Hey all well I got the RA40 on the road over the weekend took it for a wrap around the block and something didnt feel right....
    when I turn the first corner and let go of the steering wheel it wouldnt self center like it used to I had to turn it back to center myself.
    The steering didnt feel stiff but when I got it home I put it on the stands and I couldnt turn the wheels by hand frim the rim.
    My ?? is shoud I be able to rotate the steering by pulling on the wheels and how can I fix it, I thought of undoing the nut on the manual steering box and loosning it there but I didnt tuch the steering box when I took the steering off.
    Any help would be great
    Bevan
    Current rides
    Teal ST204 Celica
    Blue RA40 celica
    Default Re: help with steering
    re-check your recent work - you should be able to turn the wheels with the car on stands.
    even mine with stupid amounts of castor and shitty rubber will self-centre.
    Apparently I'm a Backyard Mechanic PULSE's Avatar
    From my knowledge of what I've read surrounding this topic, usually when steering wont self centre its because of the nut on the steering box being too tight, though from what I've heard you should be careful about how much you loosen it, it shouldn't need much. Basically because its too tight, its too hard for you to turn the wheels by hand. and its also too hard for the car to self centre, but by using the steering wheel you have more leverage and are able to turn it. I'm pretty sure if you loosen it too much you will get free play in steering, where there is a section that if you turn steering wheel, the wheels dont start turning until you hit a certain point.
    Cheers, Matt
    Sep 2007
    Thanks guys ill give it a go and let you know what happens
    Current rides
    Teal ST204 Celica
    Blue RA40 celica
    Yeah, it does sound like the adjusting screw is too tight.
    Too loose = lots of play in steering
    Too tight = steering box will wear out in no time
    ****** Backyard Mechanic 79GT's Avatar
    i wil reinforce the comment about overtightening destroys the box quick as.
    had to replace mine with an ra28 box. it was well tight, and clunked and whined when driving....not a nice feeling that is for sure. be warned
  1. Holy Sh*t TA22 Steering Improvement!!!
    By 75Ta22LT in forum Tech and Conversions
    Last Post: 30-10-2008, 12:30 AM
  2. Power Steering pump what do I have?
    By Mr Multivalve in forum Tech and Conversions
    Last Post: 29-04-2007, 10:35 PM
  3. RA2x steering box tech Q's
    By Gleno28 in forum Tech and Conversions
    Last Post: 04-07-2006, 11:17 PM
  4. 74 TA22 steering
    By merc-blue in forum Tech and Conversions
    Last Post: 27-01-2006, 04:00 PM
