Results 1 to 4 of 4
Thread: how to remove a sway bar
    apprentice carpenter Grease Monkey hosking9898's Avatar
    Jul 2007
    Default how to remove a sway bar
    ok i have a ra40 with no engine in it has a better sway bar in it i made a trade with my bro how do you get it off and is it possible to get the one out of his ra40 even though it has an engine in it cheers
    Its better to be Pissed off than Pissed on
    Default Re: how to remove a sway bar
    getting it out without the engine being moved is fine, you need to undo your castor rods from both ends, undo the anti-roll bar mounts and all the linkages and it should come out.
    Jul 2007
    Quote Originally Posted by Sam_Q
    ..cheers..
    yeah no problem, oh also only undo the outer nut on the caster rod that way you wont have to do another wheel alignment when it comes back together. Let us know if it works out
  1. Idiots guide to a 1jz conversion into a MA70 bodied supra.
    By Xistant in forum Engine & Driveline Conversions
    Last Post: 12-07-2019, 06:11 PM
  2. Replies: 9
    Last Post: 12-04-2008, 06:59 PM
  3. Help! How to remove 7mgte from MA70 ?
    By Supra6 in forum Engine & Driveline Conversions
    Last Post: 10-04-2008, 09:37 AM
  4. Rt142/St141 Whiteline sway bar issues
    Last Post: 13-06-2007, 01:42 PM
