Part 1: Getting access to the ignition wiring
I started by pulling out the coin drawer on the right side of the dash. There are two screws holding it in underneath. Remove these.
With the coin drawer fully out, unclip the three harness plugs and put the drawer aside
Now there is a single screw to remove on the left of the drawer opening
Next I removed the surround on the ignition key. It just pops out and you can remove it by hand without too much trouble.
Now remove the black dash piece in front of the instrument cluster.
It pops out as it is only held in by clips. Use your fingers to gently pull up from the back - it should pop out. Go easy as you have to remove a wiring harness from each side
Right side (Light adjuster)
Left side (TRC on/off)
Put the piece safely to one side (eg. on the back seat, out of the way)
Removing this piece gives access to a screw on the left side of the dash. Remove this.
That takes care of most of the top side. Next we'll move to the bottom trim.
