1jzracing: thanks for coming to the partyWell to update I have got some ignition now but it still isn't starting. I bought some crappy leads that I am going to hack up tonight so I can use my timing light and see what is going on.
I also have to try using the other cam sensor.
To set it up sync and reg I have ne- and g(x)- joining together at pin 27, then I have ne at pin 28 and g(x) at pin 6. I just put all the values in given to me by a guy running a v4+ on a 1jz and it now gets spark. I think I could have the wrong cam sensor though which AFAIK will put my timing out 180* and that could be why it isn't starting so that is the first point of call.
At the moment I have the igniter wired for waste spark.
igt1 to igt 1&6
igt2 to igt 2&5
igt3 to igt3&4
These are all on the ecu end of the igniter so no outputs from the igniter have been changed. So the wolf will now send the signal to igt 1&6 say which will then go out to cyl's 1&6 at the same time. (I hope)
So if I can't get it started tonight then I will be back for some more help![]()
I would be very interested to know how you have wired yours up though just to check that I have done it right. And also a look at a finished ignition map would be greatI have the wolf base map in at the moment and it looks very "base"
Thanks all
