Results 1 to 15 of 17
Thread: Mig welders - what to go for??
    Default Mig welders - what to go for??
    Hi all,
    I'm looking at buying myself a mig welder and am after some help on what to get. I'd like to know what brands are good and what are bad, what to look for in them (features) and also if anyone knows of some good places to go to get one - i'm on the northside of brisvegas. So far i've looked at kempie(boc brand) coppermate, lincoln and cigweld and they are all about the same price. It's mainly going to be for car panels and odd jobs around the home and have been recommended to get something around 180amp mark. I will be using gas and would like the ability to use it for aluminium later down the track.
    Any help is much appreciated.
    Sorry if this is in the wrong section but i thought it was most appropriate here.
    bEn
    FJ40 landcruiser
    HJ47 landcruiser
    FJ55 Landcruiser
    MS65 Crown
    Default Re: Mig welders - what to go for??
    sounds good, but good luck with aluminium, it can be difficult with MIG.
    have a search, i think it has been covered a few times, try to find one that has reasonable after sales service, maybe talk to the guys at BOC, see what they reckon.
    www.vicdrift.com
    now targeting: targets
    formerly shinybluesteel
    Forum Sponsor Conversion King
    Dec 2006
    wilbo666 started a thread in non car or general car about tigs but it turned into migs, had some decent info in it. check there but if you have no luck i may find time to go into specific
    linden
    If you want use it for Aluminium then you will need a teflon liner and special feed rollers.
    The cheaper ones often just come with steel liners and can't be upgraded.
    You will also need different gas for aluminium.
    Hoppers Crossing
    i have a SIP Coppermate 170.
    It does Mild Steel and Alloy (with the right gas - alloy needs 100% Argon - MS needs Argoshield which is a mix of Argon and O2 i think?) However I can only weld very thin ally to get the penetration - IIRC ally to weld needs a bit more oomph that MS.
    This has plenty of power for all the work i've done car wise and general jobs around the home wise.
    Quote Originally Posted by Grega
    Argoshield is a mixture of argon/carbon dioxide/oxygen. Your right though, its not suitable for ally welding due to presence of oxygen. For alloy welding you would generally use straight argon. For higher current ally welding they also use argon mixed with helium.
    Rudi
    Quote Originally Posted by 7M-GTE MX73
    Rudi
    Nope - Zero oxygen in argosheild, it's there to shield the weld from oxygen. I know you need straight argon for TIG on aluminium, but that's apparently due to the AC ionising the CO2 and causing weirdness.
    I have one of these and it's brilliant... I'm pretty sure that RiceburnaGTV still has one left for sale...
    http://img.photobucket.com/albums/v6...3/DSCF0888.jpg
    It's got 4 heat/load settings (140A, 120A, 80A, and 57A) and a variable speed wire feed... I'm pretty sure it has teflon liners also...
    And it runs off a 10A plug...
    ([][][]II--LT--II[][][])
    Hi all
    thanks for the replies. The lincoln that i looked at actually had a seperate set you could buy for aluminium welding. IT included the torch with lead and wire feed inside (so you don't have to take off your old spool etc) and a switch that needs to be installed that controls alu/steel welding. IT sounded like a great idea (was 280 extra) and was told that it would be one of the best ways at using a mig for aluminium. What do we all think???
    My big concern with the lincoln is it is a U.S. made product. Their reputation from what i can gather is quite good but i haven't seen many of them here and it makes me ask the question of what happens if something breaks. Does it get fixed here or do i screwed around and have it sent back to the states. I know cigweld are made in melbourne so that wouldn't be such a problem.
    I did search for a mig thread but there wasn't really anything that seemed relevant going by topic for the past 12 mths or so. Just wanted a fresh view.
    Many thanks,
    bEn
    FJ40 landcruiser
    HJ47 landcruiser
    FJ55 Landcruiser
    MS65 Crown
    I am not yet a Grease Monkey RA23's Avatar
    Quote Originally Posted by twentyEight
    Just out of interest, how much are these things?
    Projects: No project cars left ...
    Quote Originally Posted by Ben Wilson
    Argoshield – for MIG welding
    Argoshield is the tradename for BOC’s range of shielding gases containing the following three gases:
    Argon – for its ability to create the welding arc that allows spray transfer to be achieved, increasing the amount of weld metal deposited.
    Carbon dioxide – to improve the size and shape of the weld bead through increased melting and improved fusion characteristics.
    Oxygen – to reduce the surface tension of the molten metal and droplet sizes and therefore reduce the amount of welding wire needed, and the risk of cracks.
    Straight from http://www.boc-gases.com/products_an...ases/index.asp
    Quote Originally Posted by RA23
    Normally about $1500, but where RiceburnaGTV works had a few for $500...
    wilbo's thread about TIG/MIG welders:
    http://www.toymods.net/forums/showthread.php?t=26714
    edit: fwiw: i have a SIP gas/gasless welder i got from glenfords - from memory its the 125amp model (am not at home so can't duck downstairs to check). Only cost about $450. has variable wire speed and 6 power settings. Spare nozzles and shield are from another brand and a quite cheap at trade tools.
    You need to allow more funds to get a decent gas regulator/flow control (off ebay) and allow for regular wallet raping from your nearby gas supplier for tanks of argon or argoshield.
    Hoppers Crossing
    actually chuckster brings up a good point
    tips and shields for it and to think of it the feed wheels - make sure there is somewhere that will support whatever u buy
    i havent had a problem with the SIP stuff UNIMIG stuff fits mine just fine. i think though the torche/gun is prolly a nato standard anyway but meh, my 2c.
    There you go, I would have never expected oxygen in sheilding gases...
