Originally Posted by
timbosaurus
Just leaving that spacer out will not change camber at all. I think the KE70 xmember mounts are also wider than the celica's, so you will be pushing the bottom of the wheels out and will gain some camber there regardless of using a spacer or not.
All other things equal, leaving the spacer out will raise your front roll center. This is not necessarily a bad thing, especially on a lowered car where the roll center is pushing towards the ground.
assuming you are keeping the rack in the factory location on the xmember, it shouldn't change the steering geometry too much under bump. I'm not sure how good the standard KE70 xmember is in that regard already, but it's a good starting point.
