Results 1 to 14 of 14
Thread: 2jz manual flywheel ring gear vs auto flexplate ring gear
    Junior Member Backyard Mechanic lojik's Avatar
    Default 2jz manual flywheel ring gear vs auto flexplate ring gear
    Hello
    Is anyone able to confirm or deny whether the ring gear on an auto 2jz (ge or gte) flex plate is the same unit as on the 2jzge manual flywheel? Are they compatible?
    Junior Member Grease Monkey chaserbuddy's Avatar
    Feb 2008
    Default Re: 2jz manual flywheel ring gear vs auto flexplate ring gear
    yes they are compatibale
    Penrith BC
    as in a machined shoulder to suit mounting of the auto flex plate gear.... will this shoulder also suit a manual ring gear?
    ../delete/ban
    tech moderator
    Thanks for clearing that up Ed.
    Would still like further confirmation, anyone?
    vic
    Just make sure the auto driveplate welding process hasnt made the auto ring too big for the manual flywheel.
    Dave
    Thanks for the responses, however they seem to be missing the point a little i think.
    Perhaps I can be a little more clear;
    ed_jza80 has a non standard flywheel, it was designed to have an auto ring gear mounted to it.
    I would like to buy this flywheel.
    I have a standard manual flywheel (apparently worn beyond repair by machining), I would like to use the ring gear from it on ed_jza80's flywheel.
    So I would like to know if a manual ring gear will fit the flywheel designed for the auto ring gear?
    thanks
    Guess you can't measure it because it's still in the car?
    Mos.
    Quote Originally Posted by Mos
    Mos.
    No, I can't measure it because its still at the shop that I originally took it to for machining.
    Penrith BC
    thread in summary -
    "we need a jz auto flex plate"
    anyone?
    ../delete/ban
    tech moderator
    Feb 2008
    Well my mate might have one as he did a auto/ manual conversion.
    Junior Member 1st year Apprentice Jzxbenno's Avatar
    Nov 2007
    yeah I got one if you need it
    Ditto, have a 2JZ auto flexplate lying in my garage.
    Penrith BC
    sweet - can someone send to:
    Ed Oates
    PO Box 956
    Penrith BC NSW 2751
    PM me price and ill shoot you the $$
    first in gets the booty
    ../delete/ban
    tech moderator
    You must have a mighty big [PO] box Ed
  1. Toyota Manual Gearboxes and their Ratios (W, R, V, K, T, P)
    Last Post: 05-09-2012, 01:48 PM
  2. Ae71 Auto to Manual Conversion
    By gz10 soarer in forum Engine & Driveline Conversions
    Last Post: 25-11-2007, 10:50 PM
  3. AE86 "Cusco" quick steering racks??
    By oldcorollas in forum Tech and Conversions
    Last Post: 02-06-2007, 12:13 AM
  4. I need HELP! Auto --> manual conversion in a 2jz celsior
    By Doc in forum Engine & Driveline Conversions
    Last Post: 07-03-2007, 07:41 PM
